What is the best way to add a shelby Hood Scoop
Old Apr 4, 2011 | 10:24 AM
boeing747arowair's Avatar
boeing747arowair
what are your thought on using the 65-66 bond on gt350 hood scoop. does that hold up ? with just bondo?
Old Apr 6, 2011 | 09:23 PM
jspagna1's Avatar
jspagna1
Originally Posted by andrewmp6
If you got the money i would buy the fiberglass hood with it on it.If you go the stick on type of scoop it depends how its made.You can screw it you can pop rivet it or there is always panel adhesive its glue most body shops use now its as strong as a weld.Once its on its not hard to mold in to the hood.
+1 That's the right way to do it. When adding the fiberglas scoop to the steel hood they all eventually crack and need to be redone.
Old Apr 10, 2011 | 08:53 AM
JamesW's Avatar
JamesW
mine is a Branda bolt on that was installed using panel adhesive. It's been 2 years now and no signs of cracks.... so far so good.
PaulH2
20
Jan 31, 2016 09:48 AM
Bokeo
Oct 10, 2015 08:28 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
GT350 S550 Tech
Sep 29, 2015 03:29 PM
mungodrums
Sep 28, 2015 10:54 PM
