Speedometer is fast
Old Sep 5, 2011 | 10:54 PM
Gene Lee's Avatar
Gene Lee
Default Speedometer is fast
My 1965 Mustang coupe has a rebuilt automatic transmission. The speedometer is fast, at 35 mph it reads 45 and at 65 mph it reads 77. The rear differential tag has this info, ---2---80---5DD---911---
What does this tag info mean?
Is it true that I need this info to change the gears at the transmission speedometer cable connection?
How do I determine my transmission type?
Thanks
gene lee
Old Sep 5, 2011 | 11:29 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
are your tires stock size? youll need to adjust your speedo gear on the tranny to compensate... the gears are cheap...they are matched to what ever the rear gear ratio is in your differential.
Old Sep 6, 2011 | 12:35 PM
musnicki's Avatar
musnicki
I think you'll need to step down in the speedo gear size. The gear has between 16-24ish teeth. You probably have a 19 or 20, just take it out of the tranny and count the teeth, count them a few times to get an accurate count. If you have a 20 tooth gear then goto your speed shop and pick up a 19 or 18 etc. Don't for get to lube it a little with some 80-90 oil before you put it back in and when the gear is off, I drop a drop of lube into the speedo cable as well.
I use my iphone GPS and my wifes iphone in the passenger seat to get an accurate reading and then look at my speed on the speedo. I try to get on a straight section of highway going 60 or 70mph for like 5 minutes. There are better methods for sure, like measuring distance off and marking the car (you can google them or someone will likely post a better way).
Changing your tire size, rear diff gears or tranny will mess up your speedo reading.
James
Old Sep 7, 2011 | 12:16 PM
Gene Lee's Avatar
Gene Lee
Thanks for your help, I will take that apart now to see the gear.
But I would still like my other questions answered, the tag info on the rear end and how do I determine my automatic transmission type.
thanks
gene
Old Sep 7, 2011 | 01:06 PM
1slow67's Avatar
1slow67
ROTM Moderator
I found this, but what you have doesn't match the plate he has
http://www.woodyg.com/fairlane/finfo/fordrears.html
Your transmission should be a C4 unless someone has put a later model AOD in.
Old Sep 8, 2011 | 02:12 AM
musnicki's Avatar
musnicki
Holy crap, thats a cool refrence site! I just dumped that into my favorites. Thanks for posting that.
James
articman
Jun 21, 2018 11:45 PM
Bokeo
Oct 10, 2015 08:28 PM
stealth_GT
The Racers Bench
Sep 22, 2015 02:19 PM
Sep 16, 2015 07:53 PM
