problem with headlights
Old Jul 22, 2012 | 08:54 AM
onebad65's Avatar
onebad65
Default problem with headlights
ok so ive blown a few fuses trying to turn on my headlights(not working) and ive never done anything electrical/wiring, and i was wondering does that mean i have a bad ground somewhere and its shorting? im trying to install my new HID conversion kit that i just bought and i would like to figure out what the probelm is. i pull out the headlight ****, and pop. every time. any idea? thanks for the help
Old Jul 22, 2012 | 12:18 PM
lucasp's Avatar
lucasp
You might have a bad headlight switch. Which is not unusual for early mustangs.
Old Jul 23, 2012 | 07:38 AM
onebad65's Avatar
onebad65
are you talking about the actual switch, the **** that you pull out to turn on the headlights?
Old Jul 27, 2012 | 04:52 PM
Jonk67's Avatar
Jonk67
The headlight switch is the relay on mustangs, it's in the dash behind the ****. How did you wire in the new headlight kit you got? Whether you tapped into the original headlight wiring harness or another wire in the engine bay it sounds like you are overloading the circuit. How much amperage does the light kit require? and is it for the pair of lights or each?
What fuses are you blowing? Amp rating and location in fuse box (what does the fuse control normally?)
Jon
StalkerGT
Nov 28, 2015 03:09 PM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
ccdguy
Sep 19, 2015 05:20 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
amandahchase
Sep 3, 2015 10:09 AM
