engine swap questions (pix inside)
Old Oct 20, 2012 | 07:40 AM
  #21
JamesW's Avatar
JamesW
i'll get you one today
Old Oct 20, 2012 | 11:35 PM
  #22
lucasp's Avatar
lucasp
Thank you,
Old Oct 21, 2012 | 10:17 AM
  #23
JamesW's Avatar
JamesW
Here's a few pics of the belt routing
http://www.midnightdsigns.com/james/images/serpentine/
Old Oct 21, 2012 | 12:59 PM
  #24
Mustangdemon67's Avatar
Mustangdemon67
phenomenal work james, did you set everything up yourself?
Old Oct 21, 2012 | 02:55 PM
  #25
JamesW's Avatar
JamesW
I'm sure that setup you have is working fine. I didn't think about a stationary idler pulley with a tensioner pulley originally, but bought the Trick flow Air/PS eliminator bracket that relocates the tensioner arm to the driver's side. it couldn't keep enough tension and squalled all the time, so I canned it.
I've also got a 72 F100 (son) that we dropped an EFI5.0 with AOD in.
here's the photos
http://www.midnightdsigns.com/AJ/
Old Oct 21, 2012 | 03:26 PM
  #26
Mustangdemon67
your a pro james, you and your son do amazing work
Old Oct 21, 2012 | 08:26 PM
  #27
lucasp's Avatar
lucasp
awesome set-up James, I will definitely pick up a set.
Thank you,
Old Oct 21, 2012 | 09:28 PM
  #28
JamesW's Avatar
JamesW
of course, the other option is to get a standard rotation water pump and just run the belt around the crank, wp and alt like a standard v belt
Old Oct 31, 2012 | 12:42 PM
  #29
lucasp's Avatar
lucasp
That would be too easy😃
Old Nov 18, 2012 | 08:05 PM
  #30
lucasp's Avatar
lucasp
What oversize radiator can I use for my '65 swap with minimum mod?
