Looking for Performance Upgrades during rebuild of my 68' 302
My Pony has sprung a purdy bad leak in the rear main seal, and I have decided to pull and rebuild the motor while fixing it. As far as I know, it hasn't had any major service like this since 1991 when it went through a frame off restore.
As the head of a household of 5, I am on a pretty tight budget. However, I would be deeply upset, if during the rebuild of my motor, I didn't take full advantage of any cheap or simple modifications to gain some extra performance.
As of now, I am fairly certain everything in the motor is original or original replacement parts. It is the 302 J Code, and I am not necessarily dedicated to keeping everything original, as the color schemes etc on my 68' are not.
Let me know your thoughts out there, and I will be sure to answer any questions you need to throw out some idea's. Thanks!
A few images of the last work done:
https://plus.google.com/photos/11529...NCEkPGpkdiskgE
Thanks for the quick reply! Any idea's how much gains I could be looking at for each? I plan to run through all my options with cost vs gain to get some perspective on what would be my best options.
Each won't do...must be done as a combo. Alum heads will yield the most power when combined with the other parts (>50hp). P&P those little 302 heads won't get much (<25?). Download a free 'dyno2000' and play around before spending any money.
change your rear gear ratio 2 sizes.
if you want more power after that buy a set of ported heads from powerheads.com or a set of eddy e street heads.
comp xe262h cam.
crane lifters
comp roller tip rocker arms.
chromolly push rods.
make static compression around 9.5 - 10.0
use premium gas
cloyes true roller chain set
hedman elite shortie headers
mill the block so the pistons are .003" - .005 be"low the surface.
eddy performer intake.
try a 1 inch 4 hole tapered spacer.
quick fuel sl600vs carb
comp xe262h cam.
crane lifters
use premium gas
Galactic
04-29-2019 02:56 PM
mungodrums
Suspension
09-07-2015 07:22 PM
M3hunter
09-05-2015 03:42 PM
