65 steering shaft thread size
Old Apr 29, 2019 | 07:58 AM
pilotB737's Avatar
pilotB737
Default 65 steering shaft thread size
We're trying to replace the steering wheel but ran into issues.
When using the steering wheel puller, the threads of the shaft were slightly damaged. Tried using a file to repair but no luck yet.
What is the thread size?
May also need to replace the nut. Nut size?
Maybe need a die set to repair threads?
Thanks, picture attached.
Old Apr 29, 2019 | 11:04 PM
imp's Avatar
imp
Can you get someone who has a dial caliper or micrometer and measure the diameter over the threads? I've had them apart many times, but very long ago. I'll guess it's about 5/8" diameter, but maybe smaller, just a guess. A thread gauge would tell you the number of threads per inch. Fixing that damage with a threading die would be difficult, hard to start it straight. Is the nut OK, not damaged? Take it to an Ace Hardware or similar, ask the guy to find a bolt that threads into it; he can tell you the bolt thread size and pitch.
Failing in all of this, if nut is OK, get a hand grinder or disc grinder, and while another rotates the shaft gripping the spline with Channel-lock pliers, grind the end of the shaft forming an angled bevel removing the buggered-up threads.
Old May 3, 2019 | 06:32 AM
pilotB737's Avatar
pilotB737
Default Got it
Thanks for the reply. A local machine shop loaned him (my son) the correct die size (I believe it was 5/8"...like you said) and that did the trick. New wheel installed and looks great.
Old May 3, 2019 | 10:49 PM
imp's Avatar
imp
Glad I could help!
00blackstang
Wheels & Tires
Feb 19, 2013 08:44 PM
pwrl3ss
Jul 4, 2008 05:17 PM
500 Blue
May 2, 2008 02:42 PM
CroDalmatinac
Jan 6, 2008 07:05 AM
Shifty101Easy
Mar 7, 2006 04:19 AM
