The bolts from hell...
Old Mar 8, 2006 | 09:56 PM
  #21
dcohen's Avatar
dcohen
Default RE: The bolts from hell...
wd-40 isnt much better than water, get something like PB blaster, liquid wrench or gibbs pentrating oil
Old Mar 8, 2006 | 10:00 PM
  #22
Soaring's Avatar
Soaring
I ♥ Acer
Agreed. WD-40 is a quick fix for squeaky things, but dries up in a few days. I sure wish I had stock in WD-40 though.
Old Mar 8, 2006 | 11:24 PM
  #23
tylerdru's Avatar
tylerdru
Plasma cutter.
Old Mar 8, 2006 | 11:56 PM
  #24
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: tylerdru
Plasma cutter.
Yep. If you have enough money to actually own a plasma cutter, then you probably could afford for someone else to do the work for you.
Old Mar 9, 2006 | 12:23 AM
  #25
Baker's Avatar
Baker
ORIGINAL: Soaring
ORIGINAL: tylerdru
Plasma cutter.
Old Mar 9, 2006 | 03:01 PM
  #26
baddog671's Avatar
baddog671
-Yep. If you have enough money to actually own a plasma cutter, then you probably could afford for someone else to do the work for you.
My buddy actually has a plasma cutter but my 67 cant leave my house so that makes it difficult. Wouldnt making a bolt hot and then spray it with wd40 cause a fireball? I dont want any fire when my face if inches away!
Old Mar 11, 2006 | 02:07 AM
  #27
baddog671's Avatar
baddog671
Heres a pic of the bracket and bolts. This photo is decisiving. It looks like there is plenty of room, but the gas tank lip is one inch in front of the nut and only looks open because of my angle...
Old Mar 11, 2006 | 04:29 AM
  #28
67t5ponycoupe's Avatar
67t5ponycoupe
Grind the nut off
Old Mar 11, 2006 | 08:53 PM
  #29
baddog671's Avatar
baddog671
With...?
Old Mar 11, 2006 | 09:39 PM
  #30
67t5ponycoupe
Um let me think...A grinder
