Big Problem
Old Mar 8, 2006 | 05:23 PM
bdwjdw's Avatar
bdwjdw
Default Big Problem
I was finishing up my vintage air install yesterday so I will have the inside done for when my motor gets finished Friday. After I got all the wires connected I decided that I was going to check and make sure the blower works and it did. Well when I started to reinstall the controls the switch hit a peice or metal and guess what....................It arked. Now I don't have power to ANYTHING on the car. Well I checked all fuses, replaced the relay (because I already had a new one) and i still have nothing. Anouther strange thing is that when this happened I went to turn the key off and it was stuck. Now it just moves back and forth. I ordered a new one that was supposed to be here this afternoon so at least that will be fixed. Is there something that I am overlooking? What else could be wrong for me to not have power to anything in the car?
Old Mar 8, 2006 | 05:29 PM
tylerdru's Avatar
tylerdru
Default RE: Big Problem
The battery? Voltage regulator? you need multimeter to check the power to the battery.
Old Mar 8, 2006 | 05:30 PM
bdwjdw's Avatar
bdwjdw
already have, 13.19 volts
Old Mar 8, 2006 | 05:55 PM
Soaring's Avatar
Soaring
I ♥ Acer
Sounds like you burned up the switch. Wait until you get the new one in, then get back if you still have problems.
Old Mar 8, 2006 | 06:44 PM
bdwjdw's Avatar
bdwjdw
Thats kinda what I thought. I've already got the lock cylinder out but how do you diconect the switch?
Old Mar 8, 2006 | 06:49 PM
Soaring's Avatar
Soaring
I ♥ Acer
Try this.....
http://www.geocities.com/a65ragtop/V...ey_switch.html
Old Mar 8, 2006 | 08:34 PM
bdwjdw's Avatar
bdwjdw
I got the new ignition switch installed and I still have no power. What else is there. I'm getting REALLY frustrated!!!!!!!!!!!!!![sm=headbang.gif]
Old Mar 8, 2006 | 08:48 PM
bdwjdw's Avatar
bdwjdw
Default RE: Big Problem ///////UPDATE\\\\\\\\
Well I went back out to my car looking at everything and I decided I was gonna try things that I least expected because that usally winds up being the problem. So I decided I was going to relocate the ground from my battery, even though it was working perfect were it was at before. So I move the ground and I look up and notice I have interior lights so I get in the car, turn the key and discover everything is now working as it should and I am VERY excited!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!
Old Mar 8, 2006 | 09:15 PM
Soaring's Avatar
Soaring
I ♥ Acer
Looks like you are going to have to trace down the burned wire or relay. Here are the wiring diagrams, good luck.
http://www.themustangshop.com/index..../resources.cfm
jma2
Jul 10, 2023 01:00 AM
Luke9222
Oct 22, 2015 11:55 PM
musnicki
Sep 23, 2015 07:11 AM
MasterLanMan
Sep 13, 2015 08:21 PM
DoctorScary
Sep 9, 2015 07:53 AM
