Drip Rails Problem
Old Mar 9, 2006 | 07:20 PM
Shifty101Easy's Avatar
Shifty101Easy
Default Drip Rails Problem
is it hard and expensive to replace drip rails??
my passenger side has a little bit of rust are after i was just sanding it down to see what was going on in there.....seems like a pain to replace....how do you even repair that? is there premade pieces you can buy to have someone weld it on for you like tail panels, quarter panels, etc etc....?
Old Mar 9, 2006 | 08:12 PM
gizahuna's Avatar
gizahuna
Default RE: Drip Rails Problem
I replaced the driprails on my 68 coupe when I restored it. It wasn't too bad if you know the trick to getting them off and on. You can get them off easily with a bottle opener, kind of like opening up a bottle. Putting them on was as easy if you move from the front of the car to the back working slowly. You will probably ding it up a little but it should be too bad. I originally bought the repro's but I had a hard time getting them to fit. So I went down to the local junkyard and found a couple in good shape and they fit great.
Check out this link to help....good luck
http://www.mustangmonthly.com/howto/14158/index.html
Old Mar 9, 2006 | 08:15 PM
Shifty101Easy
no im talking about the drip rails themselves, not the mouldings....
i took the mouldings off and it was nasty under neath on the metal....
Old Mar 9, 2006 | 08:20 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: gizahuna
That is some good information about how to take off and replace the drip rail mouldings, but I think he is talking about the drip rails themselves. Those are welded on. You have to drill out the welds, clean up the rust, replace roof metal, then replace with new drip rails. Not an easy or cheap job.
Old Mar 9, 2006 | 08:30 PM
Shifty101Easy
yay....i think i'll go jump off the golden gate bridge now.
or maybe just rob a bank....
Old Mar 9, 2006 | 08:37 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: Shifty101Easy
A lot of guys just cut out the cancer in the affected area and repair the drip rail in that one small area. It depends on how much roof damage you have. But, at any rate, you will have to peel back the head liner on the inside so you don't burn it with the welding you will have to do. Then, after it is repaired, you will need to prep and paint the area. Like I said, not easy or cheap fix.
Old Mar 9, 2006 | 08:41 PM
Shifty101Easy
i ripped my headliner out because it had tears and stuff in it, so its not even a factor.....
theres no roof rust....its just the actual rail.....hmm...
Old Mar 9, 2006 | 09:19 PM
Soaring's Avatar
Soaring
I ♥ Acer
Then take out that rail area, and manufacture a new small roof rail to patch in. Otherwise, grind down the area around the rail area ,POR 15 the heck out of it, and put the putty back in.
Old Mar 9, 2006 | 09:25 PM
Shifty101Easy
im not clear on what por 15 actually is....is it paint that seals our rust? or paint that eats rust? or is there differnt kinds?
where do you get yours from?? order it or go to the store like kragen auto parts?
Old Mar 9, 2006 | 09:27 PM
351foxstang's Avatar
351foxstang
is it as bad as mine???[&o]
(still haven't fixed them yet)
[IMG]local://upfiles/19521/405EA185CDA04B61A0B3F8BAA3C05D46.jpg[/IMG]
[IMG]local://upfiles/19521/126AB4B083BE415F898197F525E8D5D9.jpg[/IMG]
