Alternator Swap Out
Old Mar 9, 2006 | 09:25 PM
cjbettis's Avatar
cjbettis
Default Alternator Swap Out
Hi this is my first post on this forum. Great looking format by the way. I have a '65 Inline 6 and need to swap out the alternator. It looks pretty easy, but never worked on cars before. (One of the reasons I bought this car--simple way to learn) Any advice/pics of this or does anyone know of a link to download the service manual?
Thank you so much!!
Old Mar 9, 2006 | 09:53 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Alternator Swap Out
ORIGINAL: cjbettis
Thank you so much!!
Hello Chris, and welcome to the classic section of the Mustang Forums. You can get a ton of information at this section about your vintage/classic mustang. Now, regarding your alternator. I will assume you have taken off your alternator and took it to a parts place to have it analyzed. If not, then that is your first job. If you have done that, and you know that you need to replace the alternator, then it is an easy job which only requires you to take off the old alternator with two bolts, then replacing it with the new one. Take note of which wires go to which terminals. Get a piece of paper, and make a drawing diagram of the hook-up before you unhook it. Put it all back together just as you dissassembled it.
Old Mar 9, 2006 | 10:43 PM
cjbettis's Avatar
cjbettis
Thanks Soaring...I just finished with it and have a charger on it...well post once it starts fine
Old Mar 9, 2006 | 10:54 PM
Baker's Avatar
Baker
ORIGINAL: cjbettis
What exactly do you have a charger on?
Old Mar 9, 2006 | 10:59 PM
Shifty101Easy's Avatar
Shifty101Easy
a charger on the alternator...?
Old Mar 9, 2006 | 11:01 PM
natedizzle's Avatar
natedizzle
The battery perhaps?
Without a functioning alternator, it would run down.
Old Mar 9, 2006 | 11:56 PM
cjbettis's Avatar
cjbettis
ORIGINAL: Shifty101Easy
yeah...isn't that how you do it???
just messin' with ya...the battery of course...it ran down just like natedizzle said....only problem now is starts but alt light is still on..I am 100% sure put all connections to alt on correct...where should I check for I guess for a bad connection?
any one have schematics for each point?
I've worked on motorcycles but never cars...so while totally new to me...I am mechanically inclined (I do all servicing and performace upgrades on it myself)
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Bokeo
Oct 10, 2015 08:28 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
