squeeky alternator
Old Mar 11, 2006 | 10:19 PM
badazz68stang's Avatar
badazz68stang
Default squeeky alternator
could someone tell me the best (easiest) way to tighten up the fan belt on my 289.
the alternator squeek which im sure is caused by this is drivin me up a wall.
Old Mar 12, 2006 | 12:21 AM
6mustang6's Avatar
6mustang6
Default RE: squeeky alternator
loosen both alternator bolts, take, and pull the alternator towards the passenger side. It should tighten the belt. Hold it and tighten down bolts. YOu may need to use a pry bar or something of that nature.
Old Mar 12, 2006 | 12:39 AM
THUMPIN455's Avatar
THUMPIN455
When does it squeek? All the time, intermitently, or at a certain RPM? ALso is it a continuous squeal? If you dont have power steering then the alternator is probably it. I use a prybar under the alternator case after losening the bolts, hold it up and tighten it. Just like 6 said...
Old Mar 12, 2006 | 11:09 AM
65GTin GA's Avatar
65GTin GA
The problem here is whether the belt is too loose and it causes it to squeel. Tightening it up is fine within limits, too tight and you wearout the bearings. If you can't get rid of the squeek, very likely the alternator bearings are already going. Remember, too loose and the belt slips, too tight and you'll wearout the bearings prematurely. Should be about 1/2" deflection at the center of the belt with nominal pressure applied. There are also belt dressings available that can help quiet a noisy belt. Ultimately, if it is the alternator itself, nothing to do but replace it.
Old Mar 12, 2006 | 01:27 PM
badazz68stang
it usually squeeks the worst when you rev. the motor. its really hard to hear while just idling but really comes on when the motor is revved up.
4cylinderplus2
Oct 9, 2020 07:45 PM
Golfsito
Oct 6, 2015 11:02 AM
MasterLanMan
Sep 26, 2015 10:03 AM
Wombatnation
Sep 13, 2015 09:16 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
