POWER
Old Mar 12, 2006 | 05:19 AM
cordoba@California's Avatar
cordoba@California
Default POWER
Its just a thought but i have a 289 and is it possible to make the car raise up on take off? by just horse power! not using NOS!
Old Mar 12, 2006 | 08:34 AM
tylerdru's Avatar
tylerdru
Default RE: POWER
you need torque.
Old Mar 12, 2006 | 11:21 AM
6mustang6's Avatar
6mustang6
Default RE: POWER
yeah, torque is what will lift the car off the ground. You'd need a big engine for that. and even if you get the bigger engine, your tires would probably just spin out, like they already do..........
Old Mar 12, 2006 | 03:28 PM
valley firearms's Avatar
valley firearms
Default RE: POWER
Low gears are also recommended. You can run tires to hook up fairly decent, especially if you have a 67 and later mustang. The 65 and 66 have smaller wheel wells.
Old Mar 12, 2006 | 05:12 PM
Iskwezm's Avatar
Iskwezm
Default RE: POWER
you dont need a "big engine", just a proberly built engine.My friend just finshed a 289 putting out 414 HP and 440 ft lbs, enough for a 11 second car with a good suspension
Old Mar 12, 2006 | 05:17 PM
superdavid's Avatar
superdavid
Default RE: POWER
Hey Iskwezm, what all has he done to that 289?
Old Mar 13, 2006 | 12:30 AM
THUMPIN455's Avatar
THUMPIN455
Default RE: POWER
Yeah 440ftlbs is ALOT for a 289, would be interesting to know whats in it.
Old Mar 13, 2006 | 02:17 AM
cordoba@California
Default RE: POWER
Yes whats in it But how much Torque do u need to raise it up on take off????
Old Mar 13, 2006 | 04:49 AM
65_2plus2's Avatar
65_2plus2
Default RE: POWER
What is it that you want to do?
A serious wheel stander? (10 foot wheelies for a city block with sparks coming off your wheelie bars)
Or just to impress the babes at the local cruise?
For cheap, impress the babes…..You can take a stock 4V 289 (225hp) with 4:55 gears in the rear, soft rubber tires, a C-4 transmission with a 3,200 to 3,800 rpm stall torque converter, and weak (or shortened) springs in the front. This combo will let you do 3 foot wheelies for about 10 yards.
To just raise the front end a bit, get weak springs and shocks. A goose on the gas will pop the nose up.
For a serious wheel stander, add $10,000.
Cheers…..[sm=icon_cheers.gif]
Old Mar 14, 2006 | 08:21 PM
cordoba@California
Default RE: POWER
just to impress the babes at the local cruise!!!!!!!!!
