Control Arm Grease Fittings
Old Mar 12, 2006 | 07:43 PM
palerider's Avatar
palerider
Default Control Arm Grease Fittings
Have a 70 mustang that has a pretty bad squeak in the front end. Jacked it up today and took tires off. The uppper contol arms does not look like it has been greased in ages. Could not get to grease fittings - was looking for 90 degree fittings at auto parts store - no luck. Any suggestion - squeaking is driving me nuts. thanks
Old Mar 12, 2006 | 08:39 PM
Gingercar's Avatar
Gingercar
Default RE: Control Arm Grease Fittings
Many mustang parts vendors have the 90 degree fittings. I have not bought any yet, but I probably will soon. Most of the time the company will sell the 90 degree fittings along with the tool to install it with. Check C.J's Pony Parts on the web. Also check Virginia Classic Mustangs on the web as well. One of them should have them.
Old Mar 13, 2006 | 01:15 PM
highhilleer's Avatar
highhilleer
National Parts Depot has a two piece fitting that is easier to install and fits tighter to the arm. I'm afraid that since the arm is already making noise that it may be worn out. You can get rebuild kits for the arm or replacement units. PITA since you need to remove the arm, which requires removing the shock and spring. If you take this on be sure to use an internal spring compressor.
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
UrS4
Oct 3, 2015 06:23 AM
mdg
Oct 1, 2015 07:04 AM
UrS4
Sep 30, 2015 10:13 AM
