Lowering 64 suspension
Old Mar 12, 2006 | 10:23 PM
90lxstang's Avatar
90lxstang
Default Lowering 64 suspension
I have a 63 Falcon convertible which has the exact same suspension as the 64 Stangs, and I was looking to lower it a bit. I just had the rear leafsprings replaced about 2 months ago and it came back a little higher than its supposed to look (too much space between the tire and the body). I was wondering if there is a DIY way to bring it down a tad myself, without having to send it back into a shop.
Old Mar 12, 2006 | 11:10 PM
dodgestang's Avatar
dodgestang
Default RE: Lowering 64 suspension
Sure is....buy mid eye leaf springs and spend an hour on the driveway installing them...should be a cake walk if you just had new leafs put in.
As for the front, take the coils out, and trim 1/4 coil of each or buy 1 inch drop springs
Old Mar 12, 2006 | 11:47 PM
67t5ponycoupe's Avatar
67t5ponycoupe
If you don't want to replace the rear springs they make a spacer block that goes between the rear end housing and the leaf springs. Most kits will come with longer u bolts. You will need them with the block. Most all of your internet mustang suppliers will have them.
Old Mar 15, 2006 | 12:32 AM
Iskwezm's Avatar
Iskwezm
the "spacer block" is called a lowering block and you can get them in 1,2, or 3" sizes.Most local parts stores will have them, cost about 20-30 bucks.
lincolnshibuya
Jul 5, 2020 03:05 AM
baddog671
Jul 26, 2016 01:20 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
marc954
Sep 29, 2015 11:18 AM
