Cam Specs
Old Mar 13, 2006 | 11:44 PM
Scott H.'s Avatar
Scott H.
Default RE: Cam Specs
ORIGINAL: Riven02
Attached is a scan of the cam specs the PO installed in my 65 Mustang (289) My question is how agressive is this cam? I expect it is not a factory replacment but I dont know if it just a hair more high preformance then stock or failry significant.
[IMG]local://upfiles/20416/11335EA6CD46495C8587D04DE2324D53.jpg[/IMG]
That is a great cam for a 289. In fact, if everything else is stock, it is my favorite "old school" grind for a 289. Gives just a touch of lope at about 700rpm. Works fine with a stock automatic. Good fuel mileage with a 500-600cfm vacuum secondary carb.
In other words... Ya done good!
Old Mar 13, 2006 | 11:46 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Ok scott what do you think of my rice stomper cam?
Old Mar 13, 2006 | 11:55 PM
Scott H.'s Avatar
Scott H.
ORIGINAL: 67t5ponycoupe
Spec sheet
[IMG]local://upfiles/27838/EE2A63585BB84CAB88874EF6C38C40CE.jpg[/IMG]
That would be a lot of fun with a stroker and some tall gears. [sm=gears.gif]
Yee-Hawwww! Did you build the rest of the motor to rev? That thing would sound sweet at 7K rpms.
Something along this sound:
http://www.cobraautomotive.com/race_movies.htm
Have fun amigo! [sm=happy046.gif]
Old Mar 14, 2006 | 02:37 AM
67t5ponycoupe
It's not stroked. It's a 302 roller cam. Trick flow heads, MAC exhaust. Weiand stealth and a holley 570. HEI dizzy. T5 trans with 3.50 gears in the rear
Old Mar 14, 2006 | 01:30 PM
Riven02's Avatar
Riven02
My 289 has a performer intake, Holley 600 cfm Carb, and dual exhaust. I have an automatic transmission and 350 gears.
Old Mar 14, 2006 | 01:47 PM
angcobra's Avatar
angcobra
Spec sheet
This one is very similar to the one in my 86 GT. Be very carefull on how you time the cam. Mine is only like 1 degree different in grind with just a little more lift. I first installed it with no cam advance and then installed with 8 degrees of cam advance, it made more than 200 HP difference. The cam you have is for very high RPM
Old Mar 14, 2006 | 07:40 PM
fast66's Avatar
fast66
ORIGINAL: Riven02
The cam you have suggestedat the start of this post is very close to the Performer RPM spec. Carb and gears seem right, however, your intake doesn't quite flow well enough, and without a mild stall converter, off the line will be a little slugish. This cam also responds well to slightly increased compression, aftermarket, or modified heads/valves, and headers or extractors. If you are intending to do some of this work in the future, great selection, but if you don't, this cam may be a little large for your basically stock setup, and you may find the Edelbrock Performer 204/214 cam more suitable.
Old Mar 14, 2006 | 07:59 PM
slickman's Avatar
slickman
What would you consider a mild TQ converter?
ORIGINAL: fast66
ORIGINAL: Riven02
Old Mar 14, 2006 | 08:36 PM
fast66's Avatar
fast66
Match the stall converter to the cam rpm specs, so for a 1500 - 5500 cam, something just above the lower end of the cam spec would be good, ie 2000 rpm.
Old Mar 14, 2006 | 11:14 PM
Scott H.'s Avatar
Scott H.
Also headers and a little porting on the exhaust side. I guess that's what I like so much about this cam. You can grow your engine quite a ways before you change it. Everything you do to stock components will net an appreciable difference. Yet it performs well stock. It is also a good cam to learn tuning with. Not until you do some serious head work (or replacement) will you need to change it.
BTW: I have nothing to do with any cam company (man I'm starting to sound like a commercial for Competition Cams here ). Kind of like your "first girl", this was the basic grind that took me from 15's to a consistent low 13 with my first hot rod back in the 70's.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
baddog671
Jul 26, 2016 01:20 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
