Steering wheel
Old Mar 16, 2006 | 11:05 PM
lonos_new_curse's Avatar
lonos_new_curse
Default Steering wheel
I remember seeing something in the FAQ on how to remove the stock steering wheel and install a Grant. I've looked through the FAQ, and can't find it. Does anyone have that article, or the link?
Old Mar 17, 2006 | 12:10 AM
Shifty101Easy's Avatar
Shifty101Easy
Default RE: Steering wheel
well....on mine i just took off the pad (2 screws in the back), then twist off the horn lever type thing.......then take off the big nut.....then i should of used a steering wheel puller to pull that thing off but i just used a little league bat to pry it off because it was trash anyways.......it popped right off....
still waiting for the turn signal cam fix kit to come.....then i can put my new wheel back on.
Old Mar 17, 2006 | 10:57 AM
lonos_new_curse
Well shifty, I guess the question is: did you damage the signal cam when you took the wheel off?
Old Mar 17, 2006 | 01:16 PM
Shifty101Easy
not at all.
the cam wouldnt cancel when i bought the car, so i figured while im going to have to take it off to replace the cam repair piece, i might as well put on a new steering wheel.....
Old Mar 17, 2006 | 01:19 PM
lonos_new_curse
Good time for it---I replaced the one in my 73 F250---wasn't that tough, and sure made it easier than remembering to turn off the signal.
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
