Removing the smog pump...
Old Mar 17, 2006 | 02:25 AM
Craig67's Avatar
Craig67
Default Removing the smog pump...
Hey guys. I just removed the smog pump on my new '67 today. The belt was already disconnected and it seems that it wasn't doing anything. The only question I have is this:
When I removed the pump and drove it around the block, it sounded like it was running a lot more rich than it was before (more GLUG GLUG). I like the sound, but is that healthy? I just wanted to make sure I didn't do anything BAD. It was already disconnected, so I assume I lost some vacuum when the hoses were removed.
Is what I did okay?
Old Mar 17, 2006 | 04:18 AM
65_2plus2's Avatar
65_2plus2
Default RE: Removing the smog pump...
I did the same thing on my 67 years ago and didn’t notice a thing. Running rich will burn the eyes of the person behind you but it wont kill the motor. Adjusting the carb will make for better performance though.
Cheers.....[sm=icon_cheers.gif]
Old Mar 17, 2006 | 03:54 PM
Craig67's Avatar
Craig67
Alright cool. I'll keep it the way it is. I drove it to school today and people thought I had a V8...I just laughed...it's only a 200 lol.[:-]
Old Mar 17, 2006 | 05:13 PM
tncruiser's Avatar
tncruiser
if you removed vacuum hoses make sure you plug the ends with a bolt or somthing, a vacuum leak is never a good thing. im so old i remember when a vacuum leak would cause your wipers to stop working
Old Mar 17, 2006 | 06:48 PM
67t5ponycoupe's Avatar
67t5ponycoupe
You also have to plug the holes where the air injection went into the exhaust manifold.
Old Mar 17, 2006 | 08:17 PM
Craig67's Avatar
Craig67
Just put in bolts with the same thread?
Old Mar 17, 2006 | 11:04 PM
67t5ponycoupe
If you didn't plug those holes that is why it sounds like a V8. Bolts will not work. They will be the wrong thread pitch. Take one of the old fittings to a good parts store and they will have brass or steel plugs that you can get.
Old Mar 18, 2006 | 03:04 AM
Craig67's Avatar
Craig67
Alright. Thanks.
Old Mar 18, 2006 | 03:28 AM
surly1's Avatar
surly1
Default ...
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
Teddi
Sep 29, 2015 12:24 PM
