engine removal
Old Mar 18, 2006 | 05:08 PM
white69mach1's Avatar
white69mach1
Default engine removal
IM planning on pulling my 351w out tonight and im wondering is it best to remove the accessories before pulling it
Old Mar 18, 2006 | 05:23 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: engine removal
It depends on a couple of things. What capacity is your engine puller? Will it safely withstand the weight of the engine and all the accessories? With a 351 I would at least unhook the tranny, and take off the air con accessories such as the compressor. Secondly, do you have another set of strong arms to help guide and balance it? If not, then you may consider taking off the alternator, carb, intake, headers and fan.
Old Mar 18, 2006 | 06:55 PM
THUMPIN455's Avatar
THUMPIN455
I usually pull everything off so I know nothing is still attached. Having a ground strap or fuel line still connected is a pain. Also if you are gonna rebuild it, you will have to pull it off sometime. Might as well do it first instead of after, makes getting it out much easier.
I leave the trans in the car too, Im not fond of ATF all over my shop floor. That stuff is the slickest stuff imagineable on a smooth concrete floor.
Old Mar 18, 2006 | 07:04 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: THUMPIN455
Pulling the tranny is an option, depending on the capacity of the engine puller. That's why I asked the question about the capacity of the engine puller. Now, replacing the engine with the tranny attached poses another problem. If the engine bay has been totally refurbished, and you don't want to get any scratches, the re-installing the engine without the tranny is a good idea.
Old Mar 18, 2006 | 07:12 PM
tylerdru's Avatar
tylerdru
I cant wait to pull my engine because when i do a new one will take its place.[8D]
Granatelli Sales
Jan 20, 2020 12:34 AM
spamedic
Sep 9, 2015 12:15 AM
Sep 1, 2015 08:16 PM
kawiguy827
Sep 1, 2015 07:09 PM
