vacuum leak?
Old Mar 18, 2006 | 11:37 PM
dawtips's Avatar
dawtips
Default vacuum leak?
Ok, my carb all of a sudden started overflowing with gas on one side. So after rebuilding it, I am hearing a loud hissing sound and it certainly isn't running strong. I have sprayed carb cleaner all around the carb but I can't find any vacuum leak. Anyone have any ideas?
Old Mar 19, 2006 | 01:05 AM
badazz68stang's Avatar
badazz68stang
Default RE: vacuum leak?
Maybe check the base gasket where it mounts to the manifold.
Old Mar 19, 2006 | 01:17 AM
Iskwezm's Avatar
Iskwezm
if it was puking gas, the float is either stuck or not adjusted right, if you have a vac leak, spray some carb cleaner while it running at the base gasket, if the idle raises or smoothens out, you found the leak. also check for missing vac caps.
Old Mar 19, 2006 | 01:52 PM
dawtips's Avatar
dawtips
Well, I replaced the base gasket with a new one and I have sprayed carb cleaner all around the carb with no noticable change in rpm... I don't see any missing vac caps. This is really bugging me because I NEED TO DRIVE MY STANG!!!!
mrtrodonet
Sep 19, 2020 03:12 PM
baddog671
Jul 26, 2016 01:20 PM
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
