TRYING TO MAKE IT WORK
Old Mar 24, 2006 | 02:03 AM
KREEPER's Avatar
KREEPER
Default TRYING TO MAKE IT WORK
I HOPE I'M HEADING IN THE RIGHT DIRECTION WITH MY PLANS, I OWN 1966 FORD MUSTANG WITH A STRIAGHT SIX AND IT RUNS A LITTLE ROUGH, BUT STILL RUNS. I JUST RECENTLY PURCHASED A BIG BLOCK CHEVY 427 AND I WOULD LIKE TO PUT THIS MOTOR WHERE THE SIX IS BUT I DON'T EXACTLY KNOW WHERE TO START (WILL I HAVE TO CUT OUT MY FENDER WELL'S, NEW MOTOR MOUNTS, NEW TRANSMISSION, NEW REAREND) ANY HELP WILL GET ME ON THE RIGHT TRACK ALSO, APRIL 2006 MUSTANG MONTHLY JUST HAPPEN TO HAVE A CHAPTER ON THE SAME SUBJECT. NEED SOME HELP.
Old Mar 24, 2006 | 02:08 AM
Twister's Avatar
Twister
Default RE: TRYING TO MAKE IT WORK
ORIGINAL: KREEPER
um, NOTHING for this 66 is designed to handle the weight of this chebby, you will basically need to put a full tube chassis in it and all new suspension. you might as well make it into a drag car
Old Mar 24, 2006 | 02:41 AM
Shifty101Easy's Avatar
Shifty101Easy
you might as well sell the chevy motor and get a ford 302 and hop it up.
or a bigger ford engine but its gonna be a pain and costly...but why oh why are you putting a chevy engine into a ford car? why must this be done by all the hotrodders and everything....? why...why???
Old Mar 24, 2006 | 03:08 AM
Craig67's Avatar
Craig67
I agree with Twister. For all the work and money you're gonna have to do, you might as well beef up a Ford motor.
Old Mar 24, 2006 | 11:38 AM
Soaring's Avatar
Soaring
I ♥ Acer
I'll tell ya', it ain't a project I would want to tackle. You will have to install a Mustang II front end first thing. Then, if you are going to all that trouble and expense, why not just slap a big block Ford engine in there?
Old Mar 24, 2006 | 01:46 PM
mayh3m's Avatar
mayh3m
the big block wasn't introduced to mustangs until 67. that being said, you will require a ton of modifications to upgrade on the stock design to make it work. it's not impossible, but it'd be easier if you had a 67 or later mustang. i believe shock towers will need to be cut as the 67 and later mustangs have 2 more inches of clearance (correct me?). as noted, the suspension will not hold up at all. i'm sure a grab-a-trak suspension kit will take care of that problem though. take a look in the FAQ section at the top of the classic mustangs forum section. there's some decent information in there about your request. learn what you can on your own, then come back.
and dont worry about dropping a chevy into it. if you actually went out of your way to get that specific engine, then i'd like to have seen you just get a ford engine. but if you got that for cheap or even nothing...well, that's just neato and i'd love to see it installed.
Old Mar 24, 2006 | 05:21 PM
ideal_mustangs's Avatar
ideal_mustangs
Go with a 351W. You can make a strong enging out of it and it will be a heck of a lot easier to fit in a 66.
Old Mar 24, 2006 | 05:26 PM
BillyBobJoe's Avatar
BillyBobJoe
ya, id go with a 351W, parts are easy to find, affordable, and there are plenty of kits to stroke it, like the 408 kit.
Old Mar 24, 2006 | 07:07 PM
highhilleer's Avatar
highhilleer
Are we being had?????
Best option
1. - sell the chevy engine and install a FORD 351W, lots of experience here to help you walk through the swap.
Second best
2. - sell the Mustang, buy a Chevy and bug the bow tie boys.
drfister
May 3, 2018 10:38 PM
flash_xx
Sep 21, 2015 01:25 PM
ak98
Sep 10, 2015 10:33 PM
Goldenpony
Aug 19, 2015 08:46 PM
