Over Carbureted?
Old Mar 25, 2006 | 02:08 AM
69mach1377's Avatar
69mach1377
Default RE: Over Carbureted?
ORIGINAL: farkedup
This is my first carb'd engine car.... I'd like to kinda know what "normal" is to compare it to mine....
Normal means stock and stock was probably around 400 cfm or so, maybe 450.
Old Mar 25, 2006 | 11:47 AM
Soaring's Avatar
Soaring
I ♥ Acer
Stock 289's with Autolite/Motorcraft 4100 (up until 67 when the 4300 was introduced for polution stuff) were rated between 470-480 CFM. You may or may not be overcarbureted depending on what performance parts were added. Check the oil and see if you can smell gas in the oil. If not, then you are probably not overcarbureted, but just need to tweak the engine for a better tune.
Old Mar 25, 2006 | 11:56 AM
randy78045's Avatar
randy78045
ORIGINAL: Soaring
For $30 you can have a sample of your oil tested and excessive fuel will show up if its a problem. I was over carbed with excessive fuel in the oil but could not smell it...
http://www.oaitesting.com/
Old Mar 25, 2006 | 12:00 PM
ideal_mustangs's Avatar
ideal_mustangs
I don't have anyway to take a sound clip of my engine, because I can't get it to my computer, but it sounds just like any other stock engine you would have heard. Very smooth just sitting there idiling.
Old Mar 25, 2006 | 12:33 PM
tylerdru's Avatar
tylerdru
In another forum i was told by some guys that 600 cfm is fine for a 289. You just have to tune it really well.
Old Mar 25, 2006 | 01:16 PM
69mach1377's Avatar
69mach1377
Better to run rich than too lean. An oxygen sensor and guage is the only real way to know this, since no matter the cfm rating, you can have too much or too little fuel in the mix. CFM is how much air it will flow, not how much fuel. Fuel is controled many ways in a carb depending on idle, WOT or in between circuits. Oil analysis may indicate only if too much fuel is unburnt, not the other way around. Too lean leads to overheating the exhaust tract.
Old Mar 25, 2006 | 01:31 PM
tylerdru's Avatar
tylerdru
That is what they told me to do. Except i was told EXACTLY what to do.
Old Mar 28, 2006 | 09:31 PM
69mach1377's Avatar
69mach1377
You'd be amazed what google will get you. I wouldn't depend on forum members to supply all the information in one reply...
I found a good carb tuning site the other day, but the link is on another computer.
Old Mar 28, 2006 | 09:35 PM
randy78045's Avatar
randy78045
ORIGINAL: 69mach1377
+1
Good research involves more than one source...
Old Mar 28, 2006 | 09:40 PM
Twister's Avatar
Twister
first off, Shelby used 715 CFM Holleys, but the can and intake were different, plus Shelby's had headers (65-66)....as for a 600, it should be finewith minor mods. My brother has a 750 on his 331 with AFR's, it really depends on how the engine was built
