Over Carbureted?
Old Mar 29, 2006 | 10:41 AM
  #21
slickman's Avatar
slickman
Default RE: Over Carbureted?
You may want to check you're exhaust tips. If you can see allot of black carbon, it may be to much carb for it. Mine had that and it also had a tendency to back fire from time to time when. I had a 600 on it then, switched over to a 500 Edelbrock and all the problems were gone. No back fire and no more black carbon.
ORIGINAL: badazz68stang
I am running and Edelbrock 600cfm electric choke on my 68 289. Is this too much carb for the motor and if so what are the direct effects of this.
Old Mar 29, 2006 | 03:46 PM
  #22
highhilleer's Avatar
highhilleer
600 cfm is on the large side for a 289/302 but is certainly workable. You could go through the calibration process.
http://www.edelbrock.com/automotive/eps_sect1.html
Your "chug" at idle could be an aftermarket cam, but it could also be an indication of the need for a tune up or a vacuum leak. I would start with the basics before reworking the carb.
smbikes
Nov 9, 2006 04:26 PM
smbikes
Nov 9, 2006 02:17 PM
twiceasfastasyou
Oct 15, 2006 08:37 PM
jlauth
Dec 24, 2005 09:16 PM
