C4 from a Bronco
Old Mar 25, 2006 | 03:10 AM
Bluelightning302's Avatar
Bluelightning302
Default C4 from a Bronco
Im getting a 351w and C4 from a bronco and will be putting it in my mustang. What would need to be done to the C4 to work? the bronco is a 4x4 so Im assuming they are different, right? I currently have a 3 spd in it std. (which i do not want in there anymore).
Old Mar 25, 2006 | 03:28 AM
mayh3m's Avatar
mayh3m
Default RE: C4 from a Bronco
well i know that import all wheel drive vehicles work by having a sideways mount engine w/ a setup as front wheel drive cars normally have (drive axles in the front) and they have a yolk in the rear of the transmission connecting to a rear end. this is for permanent all wheel drive though. trucks usually have a chain coming off the transmission yolk area connecting to front driveshaft, which then connects to the front end pumpkin (much like a typical rear end). i would assume that you can use the c4 for a rear end setup with no problems.
Old Mar 25, 2006 | 06:31 AM
Magiarn71's Avatar
Magiarn71
ORIGINAL: mayh3m
Thats called a transfer case.....
Old Mar 25, 2006 | 10:02 AM
THUMPIN455's Avatar
THUMPIN455
You will need to change the output shaft and the tailhousing. The transfer case bolts directly to the trans case on Domestic 4x4s. To replace the output shaft you need to disassemble the entire trans. Its the last thing you take out and first thing you put in. Might as well rebuild it while its apart IMO... C4's are about the easiest 3 speed automatic to rebuild, next would be the Chrysler 904/727.
Old Mar 25, 2006 | 09:42 PM
mayh3m's Avatar
mayh3m
ORIGINAL: Magiarn71
ORIGINAL: mayh3m
ah details details
scenicnights
Feb 3, 2016 09:43 AM
Philhampton1
Aug 21, 2015 12:04 PM
Puleo76
Mar 5, 2006 12:57 AM
papadaze
Sep 7, 2005 01:41 PM
