Tach mounting???
Old Mar 27, 2006 | 09:53 PM
superdavid's Avatar
superdavid
Default RE: Tach mounting???
Yeah, me neither. I've always just shifted by ear, but I wanted a tach just for the cool factor.
Old Mar 27, 2006 | 10:11 PM
Baker's Avatar
Baker
Not to jack the thread but can you remove the idiot light panel on my 73 and replace it with a tach? I was going to do it but there's a circut board on the rear of the instrument cluster, is it nessesary if I have installed water, volt, and oil pressure guages? Mounting the tach on the steering column blocks my fuel gauge.
Old Mar 27, 2006 | 10:15 PM
superdavid's Avatar
superdavid
Yeah, you really do need most of that stuff. If you remove the water guage, for an example, and a hose clamp breaks, you could very easily burn up your motor and not even know it. Same thing with the oil guage.
Old Mar 27, 2006 | 10:18 PM
Baker's Avatar
Baker
Sorry if I wasn't clear; I have replaced the idiot lights with gauges. The idiots lights no longer serve a purpose. What I am wondering is can I remove that instrument cluster and replace it with an after market tach? I would probably replace the speedo and fuel gauge so they match.
Old Mar 27, 2006 | 10:22 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: superdavid
Actually, it's not just a cool factor. I use the tach on my 03 Mach1 everytime I shift. Normal driving is about 4K. I especially use it at 4th and 5th gears. I don't like to lug an engine down, so if it drops below 2K, I shift down. The medium shift point on these old 289's is about 3K. They breathe better at medium to higher RPM's. On my old 65, I can tell by ear when it starts to strain. It's just a feel.
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
