Manifold, Carb help??
Old Mar 30, 2006 | 11:54 PM
ngirg001's Avatar
ngirg001
Default RE: Manifold, Carb help??
ok another question, what year carbs are interchangable?? 1964 through 89?? all models or only certain models
Old Mar 30, 2006 | 11:59 PM
Twister's Avatar
Twister
ORIGINAL: ngirg001
um, the last carbbed Mustang was a 2.3L 1986...your question is so far off that I am not going to try to answer. Ford has used 1 barrels, 2 barrells, 4 barrells, inline 4 barrells, and even a spreadbore 4 barrell...
Old Mar 31, 2006 | 12:41 AM
THUMPIN455's Avatar
THUMPIN455
There are roughly 3 different 4 barrel carb flanges. The spread bore, like a Quadrajet or Thermoquad (not used on most Fords as they are GM and MOPAR carbs respectively) the square bore, like most Holley 4 barrels, Carter style AFB/AVS carbs, whats known now as Edelbrock carbs, and Dominator.
Some manifolds fit both square bore and spread bore carbs. But a Dominator is way too large to fit on a smaller intake and vicer versa.
For a 289 your choices are pretty much Edelbrock or Holley type carbs. I like Demon carbs for the street manners.
Old Mar 31, 2006 | 12:48 AM
Twister's Avatar
Twister
ORIGINAL: THUMPIN455
the 351C and 429's were spread bore
Old Mar 31, 2006 | 02:41 PM
THUMPIN455's Avatar
THUMPIN455
some 351C's were. as for the 429 I have seen both manifolds on them as well. But they are the only two engines offered by Ford that had them, hence why I said "not used on most Fords" If you see one on a 289/302 or a 390, let me know. I want to know more about that engine...
Old Mar 31, 2006 | 03:04 PM
Soaring's Avatar
Soaring
I ♥ Acer
The Edelbrock performer intake is nothing more than a stock intake made out of aluminum. If you are going aftermarket, consider the Performer RPM or the Weiand. Although expensive, you can't beat the Motorcraft 4100 or 4300 carb for reliability and ease of tuning. The 4300 will have the polution inlet crap on it, so just use the 4100.
Old Mar 31, 2006 | 03:08 PM
THUMPIN455's Avatar
THUMPIN455
I think I have like 3 of them 4100's sittin around someplace... Nice little carb for nice little engines.
I could be silly and recomend a sheetmetal tunnelram with two 1150 dominators on it, but someone might actually believe it would work.
Old Mar 31, 2006 | 06:44 PM
acidrain088's Avatar
acidrain088
what cfm carb are you guys running 600?
Old Mar 31, 2006 | 11:46 PM
serge627's Avatar
serge627
Ok thanks for the additional input. So, you recommend the Performer RPM with a 4100, over the stocker that I have now?
I just wanted something mildly better than the stock set up and wanted to notice that I added the power though.
ORIGINAL: Soaring
mrtrodonet
Sep 19, 2020 03:12 PM
bradleyb
Nov 27, 2015 07:50 PM
Dokilar
15
Oct 16, 2015 08:13 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
mustangheaven
Sep 29, 2015 11:00 AM
