Rear Shock Removal?
Old Mar 30, 2006 | 03:41 PM
slickman's Avatar
slickman
Default RE: Rear Shock Removal?
Okay, if grinding the stud will not work due to the lack of room to do so. Take you're socket and grind a flat on each side of the socket towards the top. Make it the size of a wrench and you can brake it lose that way.
ORIGINAL: popper
ORIGINAL: 6mustang6
what year car? if it's a 65-66, i know for a fact a wrench wont fit. So when you put the socket on the end of it, the stud comes through the socket hole???
It's a '65 coupe. Yes, the socket bottoms out on the stud before it reaches the nut.
Old Mar 30, 2006 | 03:48 PM
6mustang6's Avatar
6mustang6
smart....... i was thinking about a sparkplug type socket(with the grooves for wrench) but didn't think they had that size...... MAKE ONE.
Old Mar 30, 2006 | 04:02 PM
popper's Avatar
popper
ORIGINAL: 6mustang6
yeah, grind the stud off, or stick the socket on there, and see if you can just slide the end of the rachet on allittle to turn it, unless the stud sticks out past the 3/8 square part.
This ended up working since i was only missing it by a hair with the socket. Thanks for the tip!
Rich
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
Dragonus18
Sep 9, 2015 01:21 AM
Doogie65
Sep 6, 2015 02:55 PM
Luke9222
Sep 4, 2015 06:46 AM
Sep 1, 2015 08:16 PM
