tach problem
Old Apr 1, 2006 | 05:44 PM
acidrain088's Avatar
acidrain088
Default tach problem
i recently hooked up a tach and when i tried to test it out it looked as if the needle moved in the wrong direction. one wire goes to ground one to a positive fuse one to a switched light source and one to positive coil. what could be a reason the tach sems to run backwards. im sure the ground and coil wires are hooked up right
Old Apr 2, 2006 | 12:45 PM
69mach1377's Avatar
69mach1377
Default RE: tach problem
Did the tach have a switch for 4, 6 or 8 cylinders?
Seanam
Oct 4, 2015 10:15 AM
marc954
Sep 25, 2015 06:48 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
96stang3.8
Sep 10, 2015 06:42 AM
