Torque converter question
Old Apr 7, 2006 | 12:24 AM
z3080's Avatar
z3080
Default Torque converter question
I kind of touched on this in my last question about my engine swap. Do torque converters go bad? How are they serviced or rebuilt? How can it effect the way the car performs? THANX
Old Apr 7, 2006 | 12:58 AM
fast66's Avatar
fast66
Default RE: Torque converter question
Yes torque coverters can go bad. the internal fins can break away and this makes it less effective. Its pretty standard that when a shop rebuilds your trans, they replace the converter.
While the engin is out, this is a good oportunity to replace it with a stall converter if you have a warmer engine, if that what you want.
Old Apr 7, 2006 | 03:54 AM
z3080's Avatar
z3080
What do you mean by a warmer engine?
Old Apr 7, 2006 | 03:56 AM
Shifty101Easy's Avatar
Shifty101Easy
i think he means more hopped up.....
Old Apr 7, 2006 | 04:02 AM
fast66's Avatar
fast66
Yep, if you have a cam or other mods that mean you are producing power higher up in the rev range, and the detriment of low end torque, you may need a stall converter. Lets not go into the details here though, do a search through this section, or any of the tech sections, im sure its a topic that been done to death.
Old Apr 8, 2006 | 12:47 AM
z3080's Avatar
z3080
Thanks guys.But this engine only gets as WARM as a 76 yr. old man can drive it. Now if I can just get him to stop crashing it into my work bench!
Old Apr 8, 2006 | 12:56 AM
mustanglover66's Avatar
mustanglover66
an easy way to park a car in a garage without hiting anything is to hang a tenis ball with some string so it touches the windsheild.
Tivo304
Aug 28, 2023 12:19 PM
spamedic
Sep 9, 2015 12:15 AM
v8sn95
Sep 7, 2015 10:17 AM
