Exhaust Manifold Question ?
Old Apr 8, 2006 | 06:12 PM
hancockd's Avatar
hancockd
Default Exhaust Manifold Question ?
This is the first post of what will probably seem like some simplistic and stupid questions, but I need the help.
First, I removed the exhaust manifolds from my 65's 289 this morning, to blast and repaint. There is a tube that is connected from the passenger side manifold to the carburetor.
1. What is this tube, and it's purpose?
2. How do I remove this tube without breaking it off in the manifold. I haven't tried yet, but as I was pulling the manifold out of the car, I noticed the tubing is extremely soft, and looks like it will break with much pressure put on it.
Thanks for any help.
Hap
[IMG]local://upfiles/32612/DF321E59656A440BBE7A6708BCB5926B.jpg[/IMG]
Old Apr 8, 2006 | 06:43 PM
Decurion's Avatar
Decurion
Default RE: Exhaust Manifold Question ?
its a heat riser to make the choke open faster. depending where you live and how much you drive the car in the cold weather, youd probly be fine just getting rid of it. it doesnt actually draw exaust, but the tube runs all the way through the manifold and is heated by the exhaust, at least thats how some work, yours may draw actual exhaust. if it were mine, id probly get rid of it, but im just hard core that way.
Old Apr 8, 2006 | 07:27 PM
Scott H.'s Avatar
Scott H.
Those are readily available through National Parts Depot, and probably other Mustang parts outlets. If you don't need to remove it from the manifold, don't. It does need to be there to heat the choke pull off spring. No exhaust goes through that hose...unless you've got a broken manifold.
Old Apr 8, 2006 | 07:28 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yep, it's purpose is to supply manifold heat to the carb choke mechanism so that the butterfly on the carb will open slowly as the temp of the engine rises, therefore giving you a smooth transition from a closed butterfly to a fully open one. It is a necessary thing to keep if you are going to be putting the same exhaust manifold on after painting it, and you are going to keep the same carb system. If you are going to upgrade, then you have electric choke mechanisms offered by all the carb companies, and if that is the case, then you will not need it. It depends on what you plan to do. Here are a couple of pics of how it is hooked up.
http://pic10.picturetrail.com/VOL326.../138129853.jpg
http://pic10.picturetrail.com/VOL326.../138129851.jpg
Old Apr 8, 2006 | 08:36 PM
hancockd's Avatar
hancockd
All,
Thanks for the information on the heat riser. I would prefer to replace the part as it has seen some abuse. Obviously, it was a threaded fitting at the carb, but how about at the manifold? Is it pressed in or threaded? Thanks again for the help.
Hap
Old Apr 8, 2006 | 08:43 PM
Soaring's Avatar
Soaring
I ♥ Acer
It's pressed.
Tivo304
Aug 28, 2023 12:19 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
Emblazoned
Sep 3, 2015 10:45 PM
kawiguy827
Sep 1, 2015 07:09 PM
