Door Latch Lock Sucks
my right door latch appears to be shot.....u have to jiggle the **** in order to make it unlock so u can open it........is it "rebuildable" or do i need to order a whole new thing...???
mine did the same i had to take off my door panel and see what was going on. one of the cotter pins that held a rod broke, took me a whole day to figure it out because the rod was in the hole but when i pushed the door latch it fell out. might as well take it off because you are going to have to anyways might as well try to play around with it
well im assuming you have to take off the panel and reach your hand in there blindly and disconnect the wire things.....then unscrew it from the jamb side........easier to get out than back in it sounds like\.
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
Sep 25, 2015 06:58 PM
