WATER LEAK
when it rains water some how makes its way into my car. Only the driver side gets water and it just sets into the carpet , I have no idea where the water is comming from. Do you guys know what are the normal problem areas for leaks? or where do you think my leak is comming from? thanks
The two most likely places would be from the cowl or the bottom of the windshield. Pour about a quart of water directly into the cowl vent and see if that is the problem. If so, then do a search and see what you need to do. This has been discussed ad nauseum, so there is a lot of information by using the search engine, and in the FAQ.
jwog666
Dec 27, 2021 08:09 PM
