66 Mustang Electrical
Old Apr 17, 2006 | 11:17 PM
Witchdoctor's Avatar
Witchdoctor
Default 66 Mustang Electrical
I have a problem I can not figure out and I am hopiing one of you guys have encountered and have a remedy. I can not get my emergency flashers to work unless I put the left or right blinker on. I have looked at the wiring diagram and looks like all roads run through the indicater switch in the steerng column. I think it has been shorted out. Have you evere seen this before and if so, are my assumptions correct? Any help would be appreciated.
Old Apr 18, 2006 | 02:00 AM
Scott H.'s Avatar
Scott H.
Default RE: 66 Mustang Electrical
Kind of depends on what you mean by don't work.
to help you out let me ask a few questions if you don't mind:
1) do the brake lights work correctly?
2). When you turn the flashers on which lights (if any) light up?
3). does the cigarette lighter work
4). have you swapped the emergency flasher unit with the turn signal flasher unit?
5). do you have a test light and/or a VOM?
Thanks,
Old Apr 18, 2006 | 02:15 AM
Witchdoctor
Ok. First, Thanks for responding
Yes, the brake lights work.
The flashers were working. I found a "splice" from the previous owner into two blue wires going into the steering column. The splice was close to the column so I could only cover them with electrical tape. The emergency blinkers flashed very quickly before I found that. Now that I "repaired it, the flash for emergency is now slower. The blinkers have now stopped working. It appears the back lights for my blinkers do not light up so for whatever that reason is, I am sure that is why the left and right blinkers have stopped blinking. The cigarette lighter is not getting power. If I send power straight to the emergency flashers, it works. Otherwise the emergency flashers do not even light up unless I turn the left or right blinker on. I do have a meter. I have checked just about every wire I can find for a short.
As you can see, I have a few electrical issues. I am not too sure replacing the wiring harness is out of the question now.
Old Apr 18, 2006 | 02:18 AM
Witchdoctor
Oh Yea. The Emergency flashers do not come on at all unless the blinker is on
Old Apr 18, 2006 | 03:07 AM
Scott H.'s Avatar
Scott H.
Well, if your finding the previous owner has hacked into the harness, and you plan on keeping the car, this may be a very good time to replace the harness.
Either way, replace or repair, your into a lot of work.
Good luck with it.
Scott
NorthAmericanTuning
Mar 18, 2016 11:21 AM
Philhampton1
Aug 21, 2015 12:04 PM
drumhedd2005
Aug 13, 2015 09:59 AM
daytooday
Aug 11, 2015 09:22 AM
89blueslug
Aug 10, 2015 07:20 AM
