3 engine removal questions, well kinda 4 or 5...LOL
Old Apr 19, 2006 | 04:49 PM
z3080's Avatar
z3080
Default 3 engine removal questions, well kinda 4 or 5...LOL
I am putting a new engine in my 68 coupe. I intend to pull the engine and tranny together.
#1 Do I need to totally remove the exhaust pipes from under the car? It's a single exhaust system and the 2 pipes coming from the exhaust manifolds come together right at the rear of the tranny. I was thinking of trying to break it loose there.
#2 What is the best way to break the rusted nuts on the E. manifold to pipe connection? Penetrating oil, heat?
#3 Do I need to remove the 2 braces that go from the firewall to where the shock absorbers connect in the engine compartment and are those bolt studs welded? I cant see anyway to get to the underneath side of the bolts that are near the shock absorbers.
Old Apr 19, 2006 | 05:21 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: 3 engine removal questions, well kinda 4 or 5...LOL
The bolts on the shock tower to cowl are just bolts that you unscrew from the top, then unscrew the bolts on the cowl. You could take the pipes off at the junction like you suggested. You can try penetrating oil and heat, then get a 1/2" breaker bar with a cheater pipe and get after them. They will either twist off, or they will unscrew.
Old Apr 19, 2006 | 06:08 PM
z3080's Avatar
z3080
Thanks soar! I guess by the "tower" you mean where the shocks are.....however....these are nuts that I have access to............the bolt is welded to the tower?
Gary Ugarek
Sep 5, 2015 09:03 PM
Shifty Magoo
Aug 25, 2015 03:08 PM
69FB
Aug 18, 2015 08:50 PM
HIS S-197
Aug 10, 2015 05:47 PM
Jacob4589
Aug 8, 2015 11:00 AM
