water pump replacement
Old Apr 20, 2006 | 01:44 PM
CO_SKI_MANIAC's Avatar
CO_SKI_MANIAC
Default water pump replacement
Hello all. I am waiting my chiltons manual to arrive but in the meantime i need to replace my water pump. its the 200 CID engine on the 68. if i recall its only a few bolts and i dont think i need to remove the radiator. is that corrent? any info is greatly appreciated!
Dan
Old Apr 20, 2006 | 01:49 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: water pump replacement
You shouldn't have to remove the radiator but it might make the whole job easier. If you have installed a fan shroud you will need to remove it though to get access to the clutch fan.
You may want to consider taking a look at the Timing chain and gears since you will have a major part out of the way to make access easier. When was the last time the timing seals and chain were serviced?
Old Apr 20, 2006 | 02:07 PM
CO_SKI_MANIAC
from the looks of it never. i bought the car 3 years ago and just started doing work on it. that is a good call on checking the timing seals and chains. i think i might also have the radiator check as well.
Nick Oliver
Oct 17, 2018 04:22 AM
TfcCDR
Sep 14, 2015 12:08 PM
MusicCity615
Sep 12, 2015 07:05 AM
5.0 kevo
Sep 3, 2015 06:24 PM
