Clutch help
Old Apr 20, 2006 | 07:18 PM
Volcom66's Avatar
Volcom66
Default Clutch help
do i put back on the stock spring for the clutch or to i leave it off since im making it a cable clutch?
Old Apr 21, 2006 | 01:29 AM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: Clutch help
What spring are you talking about bro?
Old Apr 21, 2006 | 12:36 PM
lClutchl's Avatar
lClutchl
Return spring on the pedal?
Old Apr 21, 2006 | 04:23 PM
Volcom66's Avatar
Volcom66
Yes the return spring, the huge spring that is attached to the pedal. I think that is the only spring on the pedal.
Old Apr 21, 2006 | 04:36 PM
highhilleer's Avatar
highhilleer
That spring has a dual function, it assists with pedal effort when pressing the clutch and helps the pedal return to the full up position. IMHO it is needed for stock clutches. I've read that it is not needed with diaphram style clutches like center force. So what type of clutch did you install?
Old Apr 21, 2006 | 05:13 PM
Soaring's Avatar
Soaring
I ♥ Acer
I installed a firewall adjuster clutch quadrant in my nephew's 02 GT last week, and there is no spring with that kit. If that is what you are talking about, then no. The spring is not needed.
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
ccdguy
Sep 19, 2015 05:20 PM
MasterLanMan
Sep 13, 2015 08:21 PM
