Need a windsheild removal tool...
Old Apr 21, 2006 | 01:52 PM
Clu7ch's Avatar
Clu7ch
Default RE: Need a windsheild removal tool...
you can also use a piano/guitar string. you just thread it thru the rubber and using it like a saw make your way around the window. imo it's a little easier than using a box cutter (but than again, i'm just very very prone to cutting myself)
Old Apr 21, 2006 | 02:29 PM
highhilleer's Avatar
highhilleer
Guys we got two things going on here. One is removal of the trim, which is best done with the tool shown above. The other is the removal of the glass. Before ~71 the glass is held in with a gasket, which is best cut for removal. Post ~71 the glass was glued in and the piano wire works to cut the glue. See if this helps
http://links.vintage-mustang.com/FAQ...w_removal.html
Old Apr 21, 2006 | 02:42 PM
67t5ponycoupe's Avatar
67t5ponycoupe
You are the man highhilleer. I could not agree more
Old Apr 21, 2006 | 02:47 PM
highhilleer
And two things I for got to mention. The trim removal tool is available at most parts stores.
The church key (old fashioned bottle opener, before the days of twist off) is used to remove the roof trim around the doors.
Old Apr 21, 2006 | 03:17 PM
351foxstang's Avatar
351foxstang
careful i cracked mine even after cutting the rubber gasket. it was really easy to remove after that[:@]
Old Apr 21, 2006 | 05:36 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: highhilleer
AHA, now I remember about the roof trim and the church key thing. Thanks for clearing that up.
Old Apr 21, 2006 | 09:08 PM
Clu7ch's Avatar
Clu7ch
you could just go all psycho on it, grab a BFH and be all like [sm=violent053.gif][sm=shootshoot.gif][sm=chairshot.gif][sm=icon_beat.gif][sm=headbang.gif]
at least it would be fun.
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
wawagner82
Sep 13, 2015 09:02 AM
