Ignition switch removal
Old Apr 21, 2006 | 11:34 AM
rouschfan's Avatar
rouschfan
Default Ignition switch removal
Hi all,
I have a question, I have puschased a 69 grande, it has been garsged for abut 20 years, the person that i got it from has lost the key's, would it be better to remove the ignition switch an have a key cut for it ? Or purchase a new set ? Would it be cheaper to get a new one cut an then take it an have new one's made for the door's ? If so how do you remove the old one from the car ? Thank you in advance for any help.
Old Apr 21, 2006 | 01:56 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Ignition switch removal
To get the ignition switch out of a 1964-69, you will need to have the key. Since you don't have a key, you might want to contact a locksmith. You can hotwire the car to drive it to a locksmith, or you can have them come to your house.
Old Apr 21, 2006 | 02:10 PM
Clu7ch's Avatar
Clu7ch
yeah, you need the key and a pin, right? put the key in put the pin in the hole at the bottom of the ignition and turn counterclockwise to get it to release. and the opposite for installation.
Old Apr 21, 2006 | 04:08 PM
Soaring's Avatar
Soaring
I ♥ Acer
That is correct Crash, but he doesn't have a key.
rouschfan's Avatar
rouschfan
Thank's to those who responded for all your help, appreciate it
Old Apr 21, 2006 | 09:04 PM
Clu7ch's Avatar
Clu7ch
yeah, i read that. how exactly would a locksmith be able to make a new key?
Old Apr 21, 2006 | 09:26 PM
Soaring's Avatar
Soaring
I ♥ Acer
They take a mold of the inside of the ignition, then just duplicate it to make a key. It takes time, and is quite expensive, but better than just ripping out the old unit. They can also use tools to get it started, so can probably just use those tools to turn to the ACC position so that a paper clip can be inserted into the little hole, then the ignition can be removed and a new one put in its' place.
Old Apr 22, 2006 | 02:58 PM
Clu7ch's Avatar
Clu7ch
yeah, that sounds like one hell of a project. now i have to get a locksmith to let me see exactly how this works. i'm one of those weirdo's who needs to know EXACTLY how things work and get done. i used to pull apart vcr's and random appliances when i was younger cause i thought i would be albe to see how they work. i was rather disappointed when i got them open.[&o]
Old Apr 22, 2006 | 06:07 PM
Soaring's Avatar
Soaring
I ♥ Acer
See if you can find a locksmith in your area and ask them.
http://www.1800contractor.com/d.Lock...oint_id=623806
Old Apr 22, 2006 | 06:56 PM
Clu7ch's Avatar
Clu7ch
thanks
jwog666
Dec 27, 2021 08:09 PM
PaulH2
20
Jan 31, 2016 09:48 AM
bradleyb
Nov 27, 2015 07:50 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
