Temp switches
Old Apr 23, 2006 | 12:21 AM
68Midnight's Avatar
68Midnight
Default Temp switches
I know the far left one turns the heat on but the other two dont seem to do anything when i move them. Can anyone tell me what they do?
Also, did all the classics come with the windshield wiper pedal and headlight pedal?
Old Apr 23, 2006 | 01:08 AM
6mustang6's Avatar
6mustang6
Default RE: Temp switches
hmm, crap, i cant remember what my 67's are. But it's an factory AC so it might be different anyway. Are you talking about the headlight dimmer switch? yeah, all classics came with them. As far as the windshield pedal, alot came with them too. My 67 has one. But they also had electric operated washers too, instead of the pump operated.
Old Apr 23, 2006 | 01:27 AM
68Midnight's Avatar
68Midnight
Well from what i see i have no a/c.
Old Apr 23, 2006 | 01:32 AM
mustanglover66's Avatar
mustanglover66
The other two controls one controls floor heat or Defroser and the other controls the temp
Old Apr 23, 2006 | 01:19 PM
Soaring's Avatar
Soaring
I ♥ Acer
It is common for the cable ends to rust off, so you may have to replace the cables to get the defroster and temp to work. If they move really easily, then that is most likely your problem. There should be some resistance, and if hot air is not coming out of the defroster duct, the rusted cable ends are the reason.
Old Apr 24, 2006 | 04:15 PM
Charlie1's Avatar
Charlie1
Also, the cable mounts can break loose from the original cardboard plenum (the box that distributes the heat up to the windshield or down to the floor). Mine pretty much fell apart as I removed it. Replace with a plastic plenum.
lincolnshibuya
Jul 5, 2020 03:05 AM
PaulH2
20
Jan 31, 2016 09:48 AM
guitarman376
Sep 30, 2015 05:54 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
