1970 ,302 quick distributer question
Old Apr 30, 2006 | 03:41 PM
Ponyboy1970's Avatar
Ponyboy1970
Default 1970 ,302 quick distributer question
does anyone know if the distributor on a 1970 mustang 302 coupe with the stock 2 barrel motocraft 2100 carb is time vacuum or full vacuum advanced? thankyou
Old Apr 30, 2006 | 10:28 PM
THUMPIN455's Avatar
THUMPIN455
Default RE: 1970 ,302 quick distributer question
well once you put enough vacuum to it, it goes to full advance. If you connect it to manifold vacuum it will be full advance while its running, if its connected to a source that doesnt have vacuum untill a certain throttle position it will then advance but wont be advanced at idle.
Some engines run better with full advance all the time, but for the street its better to have it come in later. Usually its a port on the carb that is above the throttle blades that doesnt see vacuum at idle. Get a vacuum guage, its a cheap tool that will help you tune the car better, and know what does what and when.
Old Apr 30, 2006 | 10:40 PM
Ponyboy1970
yea i think its timed because i took the vacuum hose off the carb and at idle put my finger to feel for vacuum and their was none, the reason i wanted to know is because i bought an edelbrock 4 barrel carb and it has 2 ports for timed vacuum and full vacuum and i wasnt sure which one i connect my hose to, thankyou for your post
tmdm
May 2, 2021 02:49 PM
Galactic
Apr 29, 2019 02:56 PM
Big Al's 03
Sep 15, 2015 09:05 AM
jaiidutch
Sep 14, 2015 10:29 AM
Mustangmalo
Sep 6, 2015 05:22 PM
