HELP....
Old May 1, 2006 | 06:18 PM
68Midnight's Avatar
68Midnight
Default HELP....
When I start the car it sounds fine for a few then the starter makes this dreadful noise like im still holding the key over trying to crank it then I turn the keys to the off position and even take the keys out and it takes the car about 10 sec to shut off...wtf happened? solenoid?
Old May 1, 2006 | 06:51 PM
68Midnight's Avatar
68Midnight
Default RE: HELP....
I replaced the solenoid but the starter keeps...trying to start...even after the car is running....I'm lost.
Any help would be greatly appreciated since this is my daily driver...
Old May 1, 2006 | 06:55 PM
Soaring's Avatar
Soaring
I ♥ Acer
Sounds as though your ignition switch may be hanging in the start position.
Old May 1, 2006 | 06:56 PM
68Midnight's Avatar
68Midnight
oh...dont tell me that....that sounds expensive....
Old May 1, 2006 | 06:58 PM
Twister's Avatar
Twister
not really, a switch is about $20....it is either the switch or the starter is not disengaging...
Old May 1, 2006 | 07:04 PM
68Midnight's Avatar
68Midnight
Well I tried again and it is causing sparks on my + cable going ot the battery so Im going to quit trying that....how hard is it to replace the switch?
Old May 1, 2006 | 07:21 PM
Soaring's Avatar
Soaring
I ♥ Acer
First thing you need to do is to take out the starter and take it to an auto parts place to have it checked. The bendix spring may be shot. If the starter is OK, then take out the ignition switch and replace it. It is a relative easy process. Then, clean up all your cable ends to make sure they are clean and making good contact. http://www.geocities.com/a65ragtop/V...ey_switch.html
Old May 1, 2006 | 07:34 PM
68Midnight's Avatar
68Midnight
Thanks! They said They would have a switch to me tomorrow...so i'll check back in tomorrow I guess.
Old May 1, 2006 | 08:09 PM
Soaring's Avatar
Soaring
I ♥ Acer
OK....you can use a paper clip as the stiff wire to insert in the little hole.
Old May 2, 2006 | 08:19 PM
68Midnight's Avatar
68Midnight
Ok got the key thing out but i cant get the switch out because the "housing" is keeping it in...how do I unscrew it?.
