Over heating on Highway
Old May 14, 2006 | 04:14 PM
slickman's Avatar
slickman
Default RE: Over heating on Highway
[sm=exactly.gif]
ORIGINAL: Soaring
ORIGINAL: tylerdru
He is in canada so i think i may be able to get away with a 2 row for now. put a spring in the bottom hose.
Canada or not, if he is overheating on the highway then he is overheating. He doesn't have enough cool water running through the block at fast enough rate. Two ways to help cure that is to increase the volume of water by adding a larger radiator, and to add a high volume pump to push more through.
Old May 14, 2006 | 04:16 PM
slickman's Avatar
slickman
Just go and get a new lower rad hose with s spring in it..
ORIGINAL: UBY289
where do I get a spring for the hose?
Old May 14, 2006 | 04:22 PM
Soaring's Avatar
Soaring
I ♥ Acer
Most auto supply houses should have one in stock. If not, try a Mustang vendor. Texas Mustang sells a hose kit which includes the bottom hose with the spring in it. I just now went out to the garage and found the old hose I had taken off, and tried to get the spring out just to see if I could. Well, I can't. So, you will need to buy the hose with the spring already in it.
Old May 14, 2006 | 04:23 PM
tylerdru's Avatar
tylerdru
When the temp in ontario canada is around 70 at the high and it is 55 today, I would say that a radiator is not completely necesary right away
Old May 14, 2006 | 04:29 PM
slickman's Avatar
slickman
If he has a rad problem, it can be 40 deg outside and he will overheat if the water is not circulating.... [sm=sigh.gif]
ORIGINAL: tylerdru
Old May 14, 2006 | 04:35 PM
tylerdru's Avatar
tylerdru
But then he would overheat at slower speeds around town too.
Old May 14, 2006 | 04:51 PM
slickman's Avatar
slickman
Not totally true.. You can have just enough water circulating to keep it cool at the lower rpm's but not at high speed driving. It can also be a faulty thermostat.. The best thing to do when you start having cooling problems is to replace anything that's suspect. Like the thermostat first, replacing hoses, make sure you have the shroud in place and if you're still having issues, replace the radiator with a three or four row then the water pump with a high flow.
I have done all that to mine and I don't have any issues any more. I'm replacing the water pump with a high flow as well when install my new built up 289.
ORIGINAL: tylerdru
Old May 14, 2006 | 05:29 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, I replaced one thing at a time until I got mine right. The shroud was the last thing I added right after the overflow tank. The more I kept upgrading, the cooler she ran.
Old May 14, 2006 | 07:49 PM
tylerdru's Avatar
tylerdru
I dont know why i argue at all.I always end up being wrong.
Old May 14, 2006 | 08:16 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: tylerdru
That's OK Tyler, you are still loved. Yeah, with heating problems, the outside temp surely makes a difference with good operating systems, but if an engine is not getting good circulation with coolant, then it really doesn't matter what the temp is outside. I was stationed at Fort Richardson, Alaska, and drove a deuce and a half for my company. I was in charge of maintaining that deuce. One morning out on alert, I woke up and started that sucker with the help of a gasoline engine heater, and it immediately started heating up beyond specs. After a lot of inspection, it turned out to be a clog in the rad, so after removing that, it ran at operating temps. Again, it basically doesn't matter what the outside temp is if the internal cooling system is not working right.
PaulH2
20
Jan 31, 2016 09:48 AM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
folivier
Oct 2, 2015 05:34 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
