transmission not working after storage
Old May 22, 2006 | 03:35 PM
raphael's Avatar
raphael
Default transmission not working after storage
Have a 68 Mustang coupe 302 just taken out of storage (was in storage for 2 1/2 years)--had not been touched at all during this time. Was able to get started but unable to get car to move when shift into any gear? Goes into gear easily but no response from transmission--checked trans fluid and color looked good and fluid was present. What should be done first to find the problem? Thank you
Old May 22, 2006 | 04:41 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: transmission not working after storage
The pump is probably frozen. Sounds like you have a C4. If so, an overhaul is about 400 bux.
Old May 22, 2006 | 04:49 PM
P Zero's Avatar
P Zero
If its a stick shift car then your clutch could be seized up, that happens to cars when they sit for a long time. If its an auto, sounds like your pump went bad.
-P.
KinneyD
Jan 9, 2016 05:33 PM
yourmom6990
3.7L V6 Technical Discussions
Oct 14, 2015 10:08 PM
CarrieS
Sep 1, 2015 01:00 PM
movielover40
Aug 27, 2015 03:26 PM
Mnuckolls
Aug 9, 2015 08:54 AM
