engine swap question
Old May 23, 2006 | 09:40 PM
borsports's Avatar
borsports
Default engine swap question
question im planning on putting a 1985 302 in to my 1969 to replace the old 302 thats in it. i was wondering am i gonna have to change my raditor because of flow direction. also can i use my altenator or am i gonna need to buy a new one.
Old May 23, 2006 | 11:15 PM
mustanglover66's Avatar
mustanglover66
Default RE: engine swap question
No you don't need to change anything but the harmonic balancer and flexplate/flywheel you will need to use the ones from the 85 302 because that engine has the 50oz balance. just change the water pump out with a 69 pump.
Old May 24, 2006 | 02:36 AM
borsports's Avatar
borsports
well i think im gonna buy nw altenator just to clean up the engine bay you know i dont wanna have a new shiny engine and then this really nasty lookin water pump and altnetor. so what year water pump and altenator should i buy?
Old May 24, 2006 | 02:39 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
u also need an adapter for the clutch linkage if its going into a manual tranny car! check down a few post if so look for the post about the 92 block!
Old May 24, 2006 | 03:57 AM
borsports's Avatar
borsports
im gonna keep my c4 just im gonna buy a tougher one with an automatic/manual valvle body, but still what year water pump and altenator should i buy?
Old May 24, 2006 | 06:17 AM
bdwjdw's Avatar
bdwjdw
Old May 24, 2006 | 12:56 PM
borsports's Avatar
borsports
whats zero?
Old May 24, 2006 | 03:01 PM
THUMPIN455's Avatar
THUMPIN455
OIL PAN... you will need the older style oil pan and pick up. Front sump pan is what you are looking for, the one fron the old engine will work. Just swap it before you try to put it in there.
Use the brackets from the old 302 and get an alternator with the highest Amp rating that will fit it. You want the old style alternator 69 era. Your car isnt wired for the new style alternator, but if you want to go that route, you can find info on the swap. I'm sorry, I cant remember what it takes to upgrade. Its been a long time since I did one, almost 20 years..
Old May 24, 2006 | 03:05 PM
darth289's Avatar
darth289
ORIGINAL: borsports
Get a water pump for a 85 if you're leaving the front of the motor the way it is, and get a alternator for a 69 so you don't have to mess with wiring in case it's different!
Old May 24, 2006 | 03:58 PM
borsports's Avatar
borsports
ok thanks for the help guys
YoungStangsMan
Sep 5, 2015 07:01 PM
classic69FB
Aug 12, 2015 11:58 PM
StangMuscle
Aug 12, 2015 07:27 AM
Jacob4589
Aug 8, 2015 11:00 AM
