Radiator- how full?
Old May 24, 2006 | 10:45 AM
popper's Avatar
popper
Default Radiator- how full?
I'm wondering if I should put an overflow tank on my '65. I'm still about a gallon short of what the manual says will go in. When I filled it all the way to the top, I lost quite a bit on the ground when I warmed the engine up. Then when I rechecked after cooling I couldn't even see the coolant in there. Are you not supposed to fill to the top?... I've never had a car w/o an overflow tank.
Old May 24, 2006 | 11:31 AM
Color by WEASEL's Avatar
Color by WEASEL
Default RE: Radiator- how full?
Turn on the heater if it has one on high. If it takes the water and gets warm, then overflows, you may have blockage or a bad thermostat. Is those do not apply, don't know what to tell you. Hows the cap? Correct psi is needed. If it's weak you can get blow by. No reason under normal conditions for it to rise and fall like that do much. I'm not a mechanic but these things I mention are common water issues. Hope it helps or at least make you say, hmmmm.
Old May 24, 2006 | 01:19 PM
Soaring's Avatar
Soaring
I ♥ Acer
I put an overflow tank on mine. It's hard to get all the air bubbles out of the system. You need to burp it, and the easiest way is to put on the overflow tank and start and stop it after the thermostat opens and keep checking the overflow tank to see if it is at the minimum level. Don't take the cap off the radiator.
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
