carb issues?
Old May 22, 2006 | 06:17 PM
CO_SKI_MANIAC's Avatar
CO_SKI_MANIAC
Default carb issues?
when it rains it pours. i ran the car for about 30 min to run errands, stopped and started a few times. i got it back to my house and stalled out on me and acted like it was flooded. i waited 15 min, tried again and it sputtered to life and would only run if i kept the pedal down. its like my carb is screwy. i tried tweaking the mixture but nothing. so now everytime i fire it up it stalls and acts flooded. any ideas? my thought was fuel pump, i disconnected the line and it has pressure maybe issues with the carb?? thanks in advance...
Dan
Old May 22, 2006 | 08:29 PM
Marshall's Avatar
Marshall
Default RE: carb issues?
I was having a very very similar problem as the one that you are. To make a very long story short the problem I was having wasn't the carb but the vacuum advance on my distributor. A way you can check is to remove the vacuum advance tube from the dist and plug the hole up then try starting your car and see if that helps.
Old May 22, 2006 | 10:08 PM
palerider's Avatar
palerider
If you see gas coming in when looking on top could be a problem with floats sticking. You did not say what type of carb you have or how old. Problem I had was 40 year old fuel lines varnishing up filter.
Sounds fuel related.
1. Look into carb with someone truning over - see gas spewing - that would be floats sticking. Especially if adjusting makes no difference or
2. Unplug gas line from carb and turn over - should see gas coming out at a pretty good rate - if not filter or pump.
Take off gass line going to car and turn over - if gas coming out probably not fuel pump.
Old May 24, 2006 | 02:49 PM
CO_SKI_MANIAC
ORIGINAL: palerider
thanks for the ideas. I have checked the lines, the pressure, the float and the needle valves, all look like it should be working great. i still might rebuild the carb since i have no idea when it was rebuilt last. i know i replaced the fuel filter 5 months ago...i will double check just in case. thanks again...
Old May 24, 2006 | 02:50 PM
CO_SKI_MANIAC
ORIGINAL: Marshall
I will give that a try...never even thought it could be the vacuum advance....thanks!!
Old May 24, 2006 | 02:55 PM
Soaring's Avatar
Soaring
I ♥ Acer
How old is that gas? Pull a plug and see if it is wet. If so, then you have a flooding problem, if not, then you are starving for gas. It might be time for a carb rebuild.
uberstang1
Sep 20, 2015 06:42 PM
Sminemann
Sep 17, 2015 09:24 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
Wombatnation
Sep 13, 2015 09:16 PM
