289 question
Old May 26, 2006 | 02:43 PM
Josh66's Avatar
Josh66
Default 289 question
Does anyone know if the 289 is externally balanced or internally balanced? I need to know what type of flywheel/flexplate to use. Also mine has a harmonic balancer i dont know if that makes it external or not. Thanx.
Old May 26, 2006 | 03:01 PM
coda618's Avatar
coda618
Default RE: 289 question
I have a 67 289. I believe all, with maybe the exception of a HIPO K code 289, are externally balanced with a 28 oz. harmonic dampener. When you go to buy a flywheel, they should be able to detrmine what you need. Good luck
Old May 26, 2006 | 03:05 PM
Josh66's Avatar
Josh66
Thanx for the quick reply. What type or brand of flywheel/flexplate and starter are you using? Mine dont fit together right, the wieght on the flexplate hits the starter teeth.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
