wiring harness
Old May 30, 2006 | 06:41 PM
mlitz's Avatar
mlitz
Default wiring harness
hey guys i back... sorry i have been gone for so long but school was important for me so i could graduate and move on to bigger and better things....
so i found out the hard way that there was a short in my ignition acc. wire some were and my car went up in smoke and i thought almost lost it but pulled the ground cable fast enough. and i replaced the wire for the time being (but it is really ghetto) so i am looking for a new waring harness through my dash and to my alternator and starter cylinoyd.
any help is great thanks.
Old May 30, 2006 | 06:56 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: wiring harness
Good for you to make school a priority. The easiest way to fix your wiring problems would be to go the painless way.
http://www.painlesswiring.com/
Old May 30, 2006 | 07:04 PM
mlitz's Avatar
mlitz
so now is this the whole harness from front to rear?
Old May 30, 2006 | 07:06 PM
Shifty101Easy's Avatar
Shifty101Easy
you probably dont need that whole thing. u probably need what i need.....apparently at least.......
in another thread i was told i need the headlight wiring harness as it contains wires going to the lights, solenoid, starter, etc......mine were all sliced on the alternator fan.....
Old May 30, 2006 | 07:07 PM
Soaring's Avatar
Soaring
I ♥ Acer
You can get whatever you want. You don't have to buy the harnesses for the whole car, just the sections you need. You probably just need the dash to firewall harness unless you burned the harness for the engine bay.
Old May 30, 2006 | 07:09 PM
mlitz's Avatar
mlitz
well it fryed my plug in the back of my ignition so do youknow if it comes with one. also most of the wireing on it is crap so i dose not bother me a bit to do the whole thing
Old May 30, 2006 | 07:10 PM
Shifty101Easy
yeah, just the hundreds of dollars for wires bothers me when i need to do so many other things.
Old May 30, 2006 | 07:13 PM
mlitz's Avatar
mlitz
ya i agree. it burned most of my dash wires and all the way through my engin bay to my starter cylinoyd (+ side)
what do i need?
Old May 30, 2006 | 07:20 PM
Soaring's Avatar
Soaring
I ♥ Acer
You need the under dash harness as well as the engine bay harness. If your headlights are still working, you may not need that harness, but it would be a good idea to replace that as well. Also, if you have a few more dollars laying around, you may as well replace the harness to the trunk.
Old May 30, 2006 | 08:37 PM
Shifty101Easy
ORIGINAL: Soaring
the thing about it is.....i think the headlights can still work even if the starter dosent or whatever...im so confused on this stuff myself i dont know what to reccomend......
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
