66 convertible Console
Old May 31, 2006 | 03:37 PM
imcliff's Avatar
imcliff
Default 66 convertible Console
Can any one tell me the difference between the console for a 66 convertible automatic with air and a coupe automatic with air? How long are they?
Thanks
imcliff@***.net
Old May 31, 2006 | 04:53 PM
Scott H.'s Avatar
Scott H.
Default RE: 66 convertible Console
The convertible console is trimmed along the bottom to fit the cross bracing on the transmission tunnel that is not present on a coupe of fast back. Both consoles extend just to the rear of the front seats.
Here is a picture of the console in my '66 convertible. I do not have factory air, so you'll notice the console goes all the way up under the dash.
You can get the diagrams to trim a non-convertible console so that it fits in a convertible. It's easy to do, just go slow with the saw blade. The plastic melts at a low temperature. It reminds me a lot of the plastic models used to be made of back in the '70s.
Also there are a couple of console on ebay right now. You can see the difference in the bottom trimming between the two.
Good luck,
[IMG]local://upfiles/16598/BEAFF76704234CB987168A7C44DF892C.jpg[/IMG]
Old May 31, 2006 | 05:03 PM
Soaring's Avatar
Soaring
I ♥ Acer
Here's the one in my coupe with air. If you can't find a short console, you can always get a long one and cut it. You will need an end cap that fits at the end right under the air conditioner condenser. You can get those at just about any Mustang vendor.
Old May 31, 2006 | 05:21 PM
imcliff's Avatar
imcliff
A couple of very nice looking interiors. Hope to have mine looking that good one of these days of course don’t even pick it up until tomorrow so may take a while. Thanks for the help I was thanking perhaps I could pick one up on eBay and restore it to fit this info helps a lot.
Thanks Again
Cliff
Old May 31, 2006 | 05:45 PM
imcliff's Avatar
imcliff
Forgot to ask where do you get the diagrams?
Thanks
Old May 31, 2006 | 06:31 PM
Scott H.'s Avatar
Scott H.
IIRC, Mustangs Unlimited, or NPD.
Did you find the consoles on ebay? That's where I found mine. It was originally for a coupe. I found a picture of the convertible console, and used it as a guide to cut mine out.
SkipperCH (aka Walt). picked up the templates to do his.
Since then I've added a "Hump hugger" console that sits on top of the factory console. It has two cup holders and a center storage area with a padded arm rest that fits me perfectly.
Have fun with the new hotrod!
Scott
Old May 31, 2006 | 06:42 PM
imcliff's Avatar
imcliff
Sounds good what I have in mind for mine.
thanks
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
lovesilver
Members Mustangs
May 9, 2019 09:18 PM
jerrytubes
Oct 23, 2015 12:11 PM
guitarman376
Sep 30, 2015 05:54 PM
