Need some info on equalizer bar.......
Old Jun 1, 2006 | 03:43 AM
valley firearms's Avatar
valley firearms
Default Need some info on equalizer bar.......
Hello all, I need a little help. I have always had automatics in my Mustangs. I just purchased the manual trans, pedal assembly, etc for my 68. I did not get the equalizer bar or any of the mounts for the equalizer bar. I know I can buy a conversion plate that bolts to the bellhousing since my heads are late model and do not have the tapped hole for the stud mount. I need the frame mount, equalizer bar, and the rod that goes to the clutch fork. Is the 6 cyl and the small block equalizer bar the same? Has anyone done the T5 conversion and have these spare parts laying around? Is there a cable conversion for the top loader that will eliminate these problems? Thanks in advance!
Old Jun 1, 2006 | 03:50 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: Need some info on equalizer bar.......
the heads dont matter! it has to do with the block is the block the original? or made in the mid seventies?, there is a hyd conversion for the top loader! dont know about cable? www.mustanmasters.com this guy can get u anything u need but he like to charge for rare parts i suggest shopping around if u cant come up with it give him a call
folivier
Tennessee Regional Chapter
Oct 2, 2015 05:32 AM
RCS02v6
Sep 29, 2015 01:46 PM
junior04
Sep 28, 2015 10:53 AM
GLOCKer
Sep 28, 2015 07:36 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
