Need help installing rear u-joint!! ASAP
Old Jun 5, 2006 | 10:04 PM
19stang66's Avatar
19stang66
Default RE: Need help installing rear u-joint!! ASAP
I got them in! No more vibration problems! Thanks for the help. Oh and I didnt use the snap rings. Yes, all you need to use is a needle nose pliers.
Old Jun 5, 2006 | 10:07 PM
ideal_mustangs's Avatar
ideal_mustangs
You need to use the snap rings. They hold the caps into the driveshaft.
Old Jun 5, 2006 | 10:10 PM
Soaring's Avatar
Soaring
I ♥ Acer
Why did I say hog nose pliers? I must be suffering from CRS tonight. Of course, I meant needle nose. I guess I need to go feed the fish.
Old Jun 5, 2006 | 10:53 PM
ideal_mustangs
LOL....you had me worried there.
Old Jun 6, 2006 | 03:09 AM
67t5ponycoupe's Avatar
67t5ponycoupe
You don't need the snap rings on the part that goes to the rearend yoke. I will gaurantee that!
Old Jun 6, 2006 | 03:48 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
they put the extras in there cause some drive shafts have a different flang on them like late model mustangs and since it wouldnt be cost worthy to package them differently well u get the pic
Old Jun 6, 2006 | 11:20 AM
ideal_mustangs
Well now I've put u joints in my truck and mustang both and they used snap rings.
Old Jun 6, 2006 | 11:23 PM
67t5ponycoupe
I agree that you must have snap rings to retain the u-joint in the drive shaft but you do not need them where the u-joint goes into the rear end yoke. They don't do anything. The caps are retained by the U-bolts and the tabs on the yoke. BTY I have never seen mustang with inside snap rings like those shown. I've done a bunch of u-joint and they were always the outside kind.
Old Jun 7, 2006 | 01:54 AM
ideal_mustangs
Ohh...I must have misread that. I was thinking of the driveshaft side. My bad
Old Jun 7, 2006 | 02:09 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
ORIGINAL: 67t5ponycoupe
my 65 uses them i likethe outeside ones myself!
drfister
May 3, 2018 10:38 PM
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
Sep 1, 2015 08:16 PM
